Morrflate tensix compressor | 4WDTalk - Overlanding and offroad Forum
Overland Shark
I was just watching the below video from this channel. One question I would have liked to see answered is if you can mount that permanently using the bracket on the bottom?
Dont see why not but gawd is that huge, also look at the specs.
From their site.
  • 10.6 CFM dual cylinder compressor at 0 PSI WOW...oh wait thats at 0psi.
  • 6.5 CFM at 30 psi Not bad
  • 150 psi rated Average
  • PSI Cutoff Switch (80psi on, 120psi off) I would prefer a lower cut off.
  • 50% duty cycle (20min on, 10min off) UHH 50% at what pressure? My compressor is 100% duty cycle. You need that when your helping others.
  • 12v, 90amps peak, ~50amp running Hmmm 50 amp probably at low pressure, 90 amp is max? what pressure does it hit that at? I guarantee, the hotter it gets the more power it draws. Thats going need at least a 4gauge cable if you mount it and hardwire it.
  • 14x7x9″ external dimensions A bit Big
  • 70-75 dB noise level from 1ft distance And loud
  • Note About This Product: This compressor is not designed for 1 tire at a time. You can still air up a single flat if you need to, but the duty cycle dwindles to 2min doing 1 tire at a time. Airing up an entire vehicle, 1 tire at a time, will damage the TenSix. Better not be inflating a set of 40's or helping others fill their tires or your in trouble.
