Converting a Right hand steer to Left hand steer? | 4WDTalk - Overlanding and offroad Forum
Chad Hahn
I'm looking at a 1995 Toyota Land Cruiser that currently is a right hand steer. What is involved in converting to left hand?
Enough that you will wish you bought a left hand drive and swapped parts
Sit in it and look at the dash. everything in front of you will be replaced. None of those parts are available so your finding a part out truck. Next is the firewall. rt and left are diffrent. Now your fabbing sheet metal, swapping the gear box to the other side (Frames are diffrent for mounting) and the steering linkage has to be changed.. Some of the accessories are diffrent spots between the two. If it has power windows, the master switch wiring needs to be changes to left.
Other then that, the driveline is the same
So yeah, more work then its worth.
