Wiring up Switch Pros?? | 4WDTalk - Overlanding and offroad Forum
Carbon Dude
How much of a task is it to wire up Switch Pros? I checked reviews here and didn't see any, so now asking you all. If you have set up this system in your Jeep, what was involved in it, and were you happy with the functionality it delivered?
I've wired both switch pro and SPod. For me the hardest part is figuring out where to put the control panel. If your comfortable around wiring, it's simple.
The best advice i can give you is to draw it out first. Draw your vehicle. map out where the wires are going to run, where the controller is mounting, The route for your power feed....
You don't want to just "wing it" and figure it out as it goes. This diagram needs to include having to route around things as well as extra wire, heat shrink, terminals and maybe crimper if needed.
