Painting KC Gravity 6 Light bar?? | 4WDTalk - Overlanding and offroad Forum
Frank Vos
This thing is black, is there a way to paint this red and have it look as good? Depending on the cost to do this, I would like to get this done. I brought to powder coating shop and the stated it would be into the thousands to do this right as they would need to take literally everything apart in order to powder coat. Then reassemble. So paint is the next option that should be less, just how much less is what I'm trying to find out. Any ideas?
Why not try doing it yourself and if it doesn't go well then take it to the shop? It will barely cost you 50-60 dollars this way. Take it apart slowly to avoid any mistakes, go over it with sand paper, prep the surface well and then paint. You shouldn't have any issues
I think that is going to be expensive regardless which way you go. Why not just keep it black and change out the covers with color matching ones?
Agree, the right way to do that is to take it ALL apart and then strip things down to bar metal and then powder coat.
