Generally speaking, toe-in with large tires? | 4WDTalk - Overlanding and offroad Forum
Howling Offroad
Hey guys, generally speaking, is there any golden rule when adding larger wheels like 37" that you should toe-in or stick with factory specs?
Thank you
Normally the factory spec has a tiny bit of toe in. Depending on vehicle, it runs from 1/16-1/8 in generally. I normally set mine at 1/4 inch for taller tires. I don't see any more wear and they tend to track better at freeway speeds.
Most people don't notice the difference, I do.
If on a Jeep, be aware you may see death wobble with toe in on larger wheels. If you drive a Jeep!
