Ecoflow DELTA 2 max solar panel requirements | 4WDTalk - Overlanding and offroad Forum
Pig Pen
I know Ecoflow has a lot of proprietary connections between its devices. Would you happen to know if the solar panels you plug into the Delta 2 need to be EcoFlow panels?
Yes you can, but the solar panels will need to use MC4 connectors and the voltage from all the panels must be between 11 and 150 volts
