Best way to tell how much life a battery has left? | 4WDTalk - Overlanding and offroad Forum
Kevin and Sara
I'm referring to a 12V battery and Goal Zero. Is there a way to test each of these and see how much life they have left?
The easy answer is yes.
The long answer is,
To test either battery accurately, you need to charge them properly and test each cell. I use to be able to do that with a hydometer on a lead acid. Sealed and AGM,s made that test go away. Now we do a capacitance tester. The real nice ones are fairly accurate, the cheap ones....ehh
On the lithium, "if" the BMS has Bluetooth, you can get a reading off each cell. Otherwise you need to take them out of the case and test individually.
