Installing Z Automotive Tazer?
It looks almost plug and play.
From their site
Simple, plug-in installation – simply unplug the SGW module and plug the Tazer JL Mini in its place. Located above the OBD2 Diagnostic connector. To make it easier for removal and reinstallation for dealer visits, add on our SGW Extension Cable.
Programming part
Vehicle Settings are accessed with the engine OFF and the ignition in the “RUN” position. These are changes made to the Jeep such as tire size, gear ratios or settings which accommodate other upgrades. These changes will continue to operate after the Tazer JL Mini is unplugged.
Set up looks very simple.
I want to caution you on things like these. Make sure you remove it and put settings back to stock if it has to go for a dealer repair. Its possible to accidentally corrupt data if one of your computers needs programing. Now the car is flagged modified and you lost your warranty. I say this because these are things I hear about from the industry.
