Where to mount water on teardrop that doesn't have mounted from factory? | 4WDTalk - Overlanding and offroad Forum
Ken S
We bought a used 2019 Escapod TOPO teardrop and we want to add water on here and not really excited about bolting on Jerry cans to the side of this thing. Is there a way to put wa water tank under this or hidden?
You could always have someone make your a tank from aluminum and mount under the trailer.
If your going to do your own, look at these RECPRO
If they don't have the dimensions you want, there's loads of others who do. You will need to figure out how/where to fill it, mount it and add in a pump with lines.
Having an aluminum one made will solve the size and mounting. I would mount it just behind the axle ( in the middle if you have an independent). That will give you the best clearance.
Because their squarish, you could mount it under a sink or in a cabinet.
